For Sale Breaking Volvo Penta 2003T with 7 deg down angle gearbox.
David Robb
David Robb
GRUFFALO
Ardrossan
Clyde
Breaking above engine, will send parts by courier at cost. Reconditioned turbo, 3-5 hours running, cost of reconditioning £950.
Engine is very smokey but starts on the key. Would push eclipse 33 at 7knts at 2500rpm.
Gearbox splines show signs of wear.
Also this was a new replacement engine, fitted 2002/2003.
Parts sold,
Injectors
Engine control panel
Timing cover
Oil cooler
Gearbox
DavieRobb@hotmail.com
0777 0066 760
Christopher Turner
Christopher Turner
SANGUINE
Ramsgate
Channel/East Coast
Does the gearbox have the spline mod? If so I might be interested in that part..
Chris
David Robb
David Robb
GRUFFALO
Ardrossan
Clyde
Chris
We've only had the boat for a year and have no idea of its previous history so don't know if the spline mod has been applied. I'm guessing it hasn't as there appears to be significant wear on the splines, sorry should have mentioned this before.
Ian Anthoney
Ian Anthoney
IDLEHORSE
Dartmouth,Devon
South Coast,
Parts sold,
Injectors
0777 0066 760
hi david is it fresh water cooled?
thanks
Ian
David Robb
David Robb
GRUFFALO
Ardrossan
Clyde
thanks
Ian
Ian, it is fresh water cooled and fitted with heat exchanger in good condition. It was recently dismantled and cleaned.
Ian Anthoney
Ian Anthoney
IDLEHORSE
Dartmouth,Devon
South Coast,
Thanks David, I’m toying with converting my 2003 to fresh water cooled ! I know there was a kit you could get so should be possible? If I can get a list of the parts needed and you have them we might have a possible deal for them
Kind regards
Ian
David Robb
David Robb
GRUFFALO
Ardrossan
Clyde
Ian, we own our boat as part of a syndicate, John who is breaking the engine should be able to identify all the parts you need. I've asked him for a price. We can send pictures back and forth to make sure you're getting all the parts you need.
Ville Steudle
Ville Steudle
Note that the 2003 "optional fresh water cooling add-on kit" and the factory-installed fresh water cooling installed on the 2003T are slightly different, so have a thorough look at the Volvo drawings. This might be related to the oil cooler, which the T has but the non-T does not.
To my understanding, one important item is to make sure that the push-style seals in the pipework can all be properly clamped and held in place.
Mark Cady
Mark Cady
BLUE MOON
Wareham
Poole South Coast
Chris,
this might help, I have a 2003 raw water cooled. I have thought of modifying but cannot see much advantage of the doing the work on a 30 year old engine. I do have the full parts catalogue if you need any more info. Also page from workshop manual.
Mark
Ville Steudle
Ville Steudle
And for some further technical information from a different perspective, here is the page and manual (unfortunately only in Swedish) for the Martec retro-fit 3rd party solution:
Martec fresh water cooling for 2003
From the photos, one can see the used attachment points for coolant circulation.
Martec typically used the approach of install rubber hoses over the Volvo pipes.
(Note that the Martec solution is otherwise somewhat different due to the use of an electric circulation pump, not engine-driven like Volvo.)
Generally, while retrofitting fresh water cooling does not make an engine younger, it
a) allows for a slightly better operation point, i.e. higher temperature (thus the need for a thermostat, I think part 43 in Mark's diagram) and
b) makes winterizing the block a bit easier, as the thermostat is not in the way for draining/flushing (as the engine block circuit runs with coolant).
Hi,
Personally, if an engine has been run as raw water cooled for any significant time, I see little benefit in converting to fresh water. All the cast iron parts will be well impregnated with salt by now, so corrosion will proceed at much the same rate. The only slight benefit you may get is hotter water in the calorifier.
David Robb
David Robb
GRUFFALO
Ardrossan
Clyde
Gearbox now sold
