Mark Michel
I am in the process of possibly purchasing a 43 eclipse.the basins are beginning to ping to laminate. Is it possible to refurbish, or do they require replacing and will this involve replacing the whole heads. Further more the day heads is vey stinky, and I suspect all the waste pipes require replacing?
Finally the rudder stock appears corroded and leaking. Can one still get the top bearing.
Thanks in advance.
Thanks in advance.
